    Error: Heating fault on heater 1 (Solved)
    duet v085 max temp
    1
    • Duetfan223undefined
      Duetfan223
      Getting Error: Heating fault on heater 1
      Where can I find a setting in the config.g file that will let me push whatever upper limit there is just a little higher? I have tried setting it to 290 but notice it doesn't accept that temp. Would be nice to set it just a little higher, or change the range for the sensor so it allows slightly larger temperature swings
      v085 board, 24v 40w cartridge heater, E3D Volcano clone with 2.25mm nozzle running 2.85mm translucent green E-Sun PETG at 285 degrees, getting excellent layer adhesion, clarity and overall print quality.
      ![https://ibb.co/fFA6nT](image url)
        Duetfan223
        Ran this Gcode:
        M303 H1 S285
        PMHeater 1 model: gain 349.7, time constant 130.7, dead time 6.8, max PWM 1.00, calibration voltage 0.0, mode PID, inverted no, frequency default
        Computed PID parameters for setpoint change: P9.8, I0.327, D46.7
        Computed PID parameters for load change: P9.8,
        PMAuto tune heater 1 completed in 219 sec
        Use M307 H1 to see the result, or M500 to save the result in config-override.g
        PMAuto tune phase 3, peak temperature was 247.6
        PMAuto tune phase 2, heater off
        PMAuto tune phase 1, heater on
        PMAuto tuning heater 1 using target temperature 240.0°C and PWM 1.00 - do not leave printer unattended
        PMConnection established!
        Edit: Didn't help, still overshot 285 up to about 292 and triggered Error: Heating fault on heater 1...
        Also tried M303 H1 S285 but it defaults to S200 automatically
        Any ideas? What am I missing? Any way to just set temps in Duet over 285?
          Duetfan223
          M143 H1 S320 sets the max temperature to 320
          I added this to config.g just before the extruder PID section and it seems to work
          When I run M303 H1 S320 it completed successfully, I added it's suggested PID values to config.g
          The next print came out perfect, and there we no heater faults.
          So the answer in this case is add M143 H1 S320 to the config.g file and auto-tune the heater with M303 H1 S320.
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M109_Set_Extruder_Temperature_and_Wait
